Installation Tutorials by Platform (CMS)
Already created your perfect Elfsight widget but not sure how to install it on your website? This guide will help! On this page, you can find a tutorial that will guide you through the process of installing the widget on a website built with a specific Content Management System (CMS).
See the   ▶   icon? This article includes a video tutorial that will guide you step by step!
Not sure which CMS your website belongs to? You can easily find it with an online tool WhatCMS. Simply enter your website's URL into the search box, and it will automatically detect your CMS.
Choose your website platform to find out how to install the widget:
If your platform isn't listed, feel free to send an installation request. Our widget typically works if your platform supports JS and HTML code insertion, and we're here to help if you encounter any issues during installation!
