Displaying Click to Call only on homepage or excluding it from homepage
When configuring your Click to Call widget, you have the flexibility to select the pages where you want the widget to appear or, alternatively, exclude it from certain pages. If that page is your homepage, we provide a convenient option to do that.
- 1
Go to your widget's editor, open the Settings tab and select Pages:
- 2
Click on Specific Pages if you'd like to display the widget on your homepage or select Exclude Pages if you don't want your visitors to see it there. Then click on the Add Page button:
In the URL field, please enter the word homepage to indicate that you are referring to your website's main page:
Great! Now that you are familiar with the feature, you can effectively use it to either show or exclude the widget from your website's homepage. This flexibility allows you to customize the widget's visibility according to your preferences.
