Step 3: Customize Your Click to Call Widget Appearance
You have the ability to customize the appearance of your Click to Call widget to perfectly align with your website's aesthetic. This article will provide you with the necessary guidance to accomplish this task.
In this article
Changing colors
This particular section of the settings grants you the ability to modify the colors for each individual element within the widget:
Adjusting the font
This section will help you choose the needed font and set the font size of the text in the widget:
Adding animation
Here you can turn on/off Button Animation and set Animation interval:
Custom CSS section
In this section, you have the option to add CSS code. For instance, you can use CSS to adjust the border radius of the button to your desired preference:
For extra styling ideas, visit our community post with handy CSS codes 😊
We hope our Click to Call widget will bring more value to your website! If you need further assistance, whether it's with customization or other general queries, just contact our Support Team — we’re always happy to help!
