Setting a schedule in your Click to Call widget
When customizing your Click to Call widget, you have the option to set up a specific schedule for the widget to appear on your website. This feature provides you with the flexibility to decide when visitors see the widget, ensuring that it aligns seamlessly with your business hours or specific timeframes. Follow the steps below to configure your own schedule for the widget.
- 1
Open your widget's editor, go to the Settings tab and select Schedule:
- 2
Here, you can choose the days you need your widget to be active on your website (1) and enable the Set the Time Schedule option (2) to specify the precise time for the widget to appear on the selected days:
- 3
Adjust the time when the widget appears on the website next to the Start Time setting, and set the time for it to stop displaying next to the End Time setting:
- 4
Finally, ensure accurate scheduling by setting the required Time Zone:
Well done! You've successfully customized your widget schedule which improves the overall user experience for your visitors.
