Setting up questions and question categories in FAQ widget
When you're setting up your FAQ widget, it's important to lay the foundation by adding the questions and answers that will be featured. This article is here to guide you through that process. Let's get started on creating an engaging and informative FAQ section for your website!
- 1
Open your widget's editor, go to the Content tab, click on the Actions menu and choose to Delete the default question category:
Once that's done, click on Add Category to create a new category of your own:
- 2
Following that, set the title within the Title field and click on Icon to select a proper icon. Then you can start adding questions to this category right on this screen, by clicking Add Question:
- 3
Enter the Question and the Answer you'd like to show. You can also use rich text editor to format your answer:
- 4
Once you've added a question, you'll see it show up in your widget as well as in the list of questions in the left-hand menu. By default, questions are sorted chronologically based on when you added them. However, you can also rearrange them by simply dragging and dropping them to change their order on the list:
Great job! Once you've added all the questions and answers, it's time to install the widget on your website. For that, check out our installation tutorials - Installation Tutorials by Platform (CMS).
