Assigning widget to a project
Grouping widgets in Projects is a great way to structure your Elfsight workspace. With this feature, any widget you need to access is just a couple clicks away!
Do you want to learn more about Projects in general? If so, we invite you to explore our introductory guide - Projects: Getting Started.
- 1
To assign a widget to a project, go to the My Apps tab and pick the app you used to create the widget:
- 2
Find the widget you'd like to add to your project and click the action button (...) next to it:
- 3
Following that, click Assign to Project and choose the desired project from the dropdown window:
Please note that the widget cannot be assigned to multiple projects. You can assign it to one project only. - 4
Confirm your choice by clicking the Assign to Project button:
Brilliant! You will see a popup confirming the widget has been assigned:
By the way, don't forget that you can also create a new widget right within the project. For that, please take a look at the following guide - Creating a new widget in a project.
