Customizing Instagram Feed with CSS
You can customize the appearance of your Instagram Feed widget on the Layout, Theme, and Settings tabs. If the built-in options are not enough, use Cascading Style Sheets (CSS) to fine-tune individual widget elements.
For more guidance on applying CSS to your widgets, see our Guide to CSS Codes for Elfsight Widgets.
In This Article
Instagram Feed CSS Classes
Each customizable widget element has a CSS class you can use as a selector. The available classes depend on your widget version.
If you created your widget after August 26, 2026, use the Current Classes:
Current Classes
Class name Element
.es-widget-background-container Entire Instagram Feed widget
.es-header-title Widget title
.es-grid-layout Grid layout
.es-masonry-layout Masonry layout
.es-carousel-layout-container Carousel layout
.es-carousel-layout-item Individual item in Carousel layout
.es-carousel-arrow-control-container Navigation arrows in widget
.es-carousel-arrow-control-container-previous Previous carousel arrow
.es-carousel-arrow-control-container-next Next carousel arrow
.es-load-more-button Load More button
.es-card-container Individual Instagram post
.es-card-media-icon-slot Post type icon
.es-card-media-container Post media container
.es-card-media Post media
.es-card-text Post caption
.es-card-actions-count Like and comment counts
.es-card-actions-share-button Share button
.es-popup-feed-post-date Publication date in post popup
.es-author-name Instagram username in post
.es-avatar-image Profile picture in post and header
.es-header-account-avatar Profile picture in Account header
.es-bullets-control-item Carousel pagination indicator
.es-bullets-control-item-active Active carousel pagination indicator
.es-popup-feed-container Post container in popup
Classes for Older Widgets
Class name Element
.es-widget Entire Instagram Feed widget
.es-widget-title Widget title
.es-layout Feed layout container
.es-layout-grid Grid layout
.es-layout-carousel Carousel layout
.es-layout-grid-content Post container in Grid layout
.es-layout-carousel-content Post container in Carousel layout
.es-layout-carousel-arrow Carousel navigation arrows
.es-layout-carousel-arrow-prev Previous Carousel arrow
.es-layout-carousel-arrow-next Next Carousel arrow
.es-post Individual Instagram post
.es-post-type Post-type icon, such as video or carousel
.es-post-media Post media container
.es-post-media-image Post image
.es-post-media-video Post video
.es-post-text Post caption
.es-post-likes-count Post like count
.es-post-comments-count Post comment count
.es-post-source Instagram source link
.es-post-follow Follow link in post popup
.es-post-share Share button in post popup
.es-post-date Publication date in post popup
.es-post-location Post location in popup
.es-post-user-name Instagram username in post popup
.es-post-user-picture Profile picture in post popup
.es-post-media-carousel Media carousel within a multi-image post
.es-post-media-carousel-pagination-item Media carousel pagination indicator
.es-post-media-carousel-pagination-item-active Active media carousel pagination indicator
.es-post-media-carousel-arrow Media carousel navigation arrows
.es-post-media-carousel-arrow-prev Previous media carousel arrow
.es-post-media-carousel-arrow-next Next media carousel arrow
.es-popup Post popup
.es-popup-close Popup close button
.es-post-like-notification Post like notification
Need help turning a class into complete CSS code? See How to Create CSS for Your Widget.
The classes above are stable selectors recommended for customization and are intended specifically for the Instagram Feed widget.
How to Add CSS to Your Widget
After creating your CSS code, add it to your widget. As an example, we'll increase the text size on post cards:
 .es-card-text {
   font-size: 15px;
Open the Settings tab, scroll down, and click Custom CSS:
2
Paste the code into the Custom CSS field. Then, click Publish to apply the changes to your website:
Done! Your custom CSS is now applied to the widget.
Want to take your customization even further? Explore our public collection of CSS codes for Instagram Feed and find more ideas for your widget! 🚀
If you need any help with custom CSS, feel free to contact our Support team — we’ll be happy to assist! 😊
