Why my zip code does not work in Weather widget
You may notice that sometimes the Weather widget may display incorrect information when you add your location by its ZIP code. Unfortunately, ZIP codes aren't unique and because of this, they may broadcast the information for a completely different location from the one you had in mind.
The best way to avoid this is to add a location using its coordinates.
To find the coordinates, please open Google Maps, enter the name of the location, and press Search. In the URL, you will find the coordinates right in the beginning, after the location's name. You need to copy just the digits without any additional characters or letters, so it will look like this:
40.6451594,-73.9800254,13
Alternatively, you can place a marker on any area on the map and coordinates of this place will be displayed for you at the bottom of the page:
Copy the coordinates and then add them to your Weather widget:
Great job. You have successfully added a location to your Weather widget!
