Why my AliExpress reviews are not being updated
If you see that some of your newest reviews are not in the widget, the most general reason for not-updating the reviews is the cache. Our Reviews widgets uses 48-hours cache, so the new reviews may get displayed in your widget with a delay.
Our apps use cache to make the widget load faster and reduce the server load. Thus they don't receive data each time someone browses your widget. Instead, they make a request once in every 48 hours, pull in the reviews, store them in the cache, and display them from the cache. After the cache is expired, the widgets send a request for the reviews again, and that's when the new ones make it to your widget.
48 hours have passed and the reviews still not showing up
If it has been 48 hours since the review was posted and it is still not displayed in your widget, there may be some local issues. Please contact our Support Team, we will be happy to help you.
