Recurring Events in Event Calendar Widget
If you use our Event Calendar widget to display events that repeat regularly, you can save time by setting them to recur automatically. This guide explains how to enable recurring events and how they’re displayed in your calendar.
In this article
How to Make an Event Recurring
If you want an event to repeat, you can set it up in just a few clicks:
- 1
Open your widget editor, go to the Events tab, and select the event you want to make recurring:
- 2
Click on Repeat and select the desired option from the Repeat Event list:
Recurring events are repeated up to a certain limit to keep your widget running smoothly.
By default, the widget automatically generates up to 30 occurrences of a recurring event. For layouts with pagination (List / Grid / Masonry), the limit increases to 100 occurrences.
Here’s how it works depending on the selected frequency:
- Daily — Repeats every day (up to 30 or 100 days)
- Weekly — Repeats once a week (up to 30 or 100 weeks)
- Monthly — Repeats once a month (up to 30 or 100 months)
- Annually — Repeats once a year (up to 30 or 100 years)
If you need more repetitions than allowed, please contact our Support Team with your use case details — we’ll be happy to check if a custom adjustment is possible.
How to Set Up Custom Repetition
If none of the preset repeat options fit your needs, select Custom in the Repeat Event section. This allows you to fully control how often your event repeats:
You can choose the Frequency (Daily, Weekly, Monthly, or Yearly) and specify how often it repeats — for example, every 3 days, every 2 weeks, or every 4 years:
You can also decide when the repetition should stop. In the Repeat Ends setting, choose one of three options:
- Never — The event repeats indefinitely
- On Date — The event stops on a specific date
- After Occurrences — The event stops after a set number of repetitions
How to Set Exceptions to the Repetition
If you need to skip or modify a specific occurrence of a recurring event, you can add an exception.
In the Repeat Event section, click Exceptions, then select + Add Exception. Choose the occurrence you want to modify by its date and time:
After selecting the occurrence, choose the action you’d like to apply:
- Skip this occurrence — remove this instance from the calendar
- Reschedule to another date/time — select a new start and end date or time
That’s it! 🎉 Now you know how to set up recurring events, customize their repetition, and manage exceptions in your Event Calendar.
We hope this article helped you better understand how this feature works. If you didn’t find the answer you were looking for, please contact us. We're here to assist!
